67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Model surface pattern and material not aligned
0 Posts No Rating |
Hi
I have a brick pattern which won't align when in realistic view, despite displaying as aligned in shaded view.
I have also ensured that the surface pattern is a model pattern, as seen below.
Does anyone have a soloution to this?
Joe
![Beaucoupnice Avatar](user_avatar/46219.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
1) Check your hatch pattern size matches your texture pattern module size.
2) If (1) is ok, then go to the texture pattern image and use the X & Y parameter option to shift the texture image up/down and left and right until it aligns with your hatch pattern.
0 Posts No Rating |
I don't really understand your suggestion.
Since my texture and hatch align correctly under texture alignment I would assume the sizes are correct.
When I change the X or Y parameters it simply moves the whole pattern in that direction, yet the chimney and main wall materials still aren't aligned.
Your hatch pattern will have a size - say a tiled pattern that is 100 x 100mm.
Your texture material will be based on an image - say a JPG image of a tile. When you open the window to control that image you will see the size of the image is set by a default amount. You need to check this amount matches the hatch size as Revit has no way of scaling an image, it relies on you to define it. If these are the same, then the only possible solution it can be is that the position of the image is not aligned to the hatch pattern. So in the image window, you need to shift it up/down or left or right until it aligns.
Stair Surface Pattern Not Displaying |
Wed, Sep 8, 2010 at 10:05:09 AM
Hiding Surface Pattern For Specific Wall Material |
Thu, Feb 21, 2008 at 10:47:29 AM
Surface Pattern Not Transferring to Model |
Fri, Jun 1, 2007 at 1:28:52 PM
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
Split Faced CMU model material pattern help???!?!?!? |
Fri, Jun 1, 2007 at 2:01:39 PM
Members: | 2016941 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
