39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing wall finishing thickness without having to align it again
Mon, Jul 2, 2018 at 10:47:17 PM | Changing wall finishing thickness without having to align it again
Olzhas
Hello!
We are working with the client wh constantly changes his mind. One of the things we repeatedly do is changing wall finishing thickness. When I change 20mm render to 10mm gap is created between the wall and the render finish so I have to align it back with the wall. I wonder if there is a way to make the wall finishing stick to the wall face. Any advice is much appreciated.
Tue, Jul 3, 2018 at 3:06:46 AM | Changing wall finishing thickness without having to align it again
tim123
4 Stars: 19 Votes
Align and lock.
Tue, Jul 3, 2018 at 8:40:36 AM | Changing wall finishing thickness without having to align it again
Olzhas
Do you mean pin it? It does not work. I found that it is possible to draw wall finishes while activating snap to the inner side. This option is available when in drawing mode. This way you can change the thickness of finishing and it is always stuck to the wall.
Tue, Jul 3, 2018 at 10:03:33 AM | Changing wall finishing thickness without having to align it again
tim123
4 Stars: 19 Votes
No, I mean lock - when you align something a padlock appears - click to lock it.  The method that you describe can also be used.  Also note that if you pick the walls with the location set to 'Finish face - interior' they should also move with the walls.
Tue, Jul 3, 2018 at 10:32:07 AM | Changing wall finishing thickness without having to align it again
Did you do this finish as a seperate wall?  Why not include it in the main wall type?
Tue, Jul 3, 2018 at 10:42:11 AM | Changing wall finishing thickness without having to align it again
Olzhas
Thanks for your responses. I will try the lock method too.
Regarding the inclusion of the wall finish in the wall type - this is our office regulation. For some reason we are drawing fiishes as separate walls. I used to include finishes in the wall type durng uni years however.
Changing wall thickness issue
Thu, Oct 12, 2006 at 11:07:14 AM
Wall Core Visibility
Thu, Oct 9, 2008 at 11:53:58 AM
wall floor finishing joint
Mon, Nov 23, 2009 at 4:56:30 AM
changing line thickness in composite walls
Wed, Mar 25, 2009 at 7:11:09 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Page generation time: 1.3384
