Forums >> Revit Building >> Technical Support >> twisted objects
6 Posts No Rating |
Hi,
I am trying to make a tensile structure, but I'm having difficulties with making the shape of the sail. Does anybody know how I can make a surface which is curved in 2 ways?
Have a look at this one in the gallery:
http://revitcity.com/gallery.php?action=view&gallery_id=132
Doing tensile structures with Toposurface found under Site in Revit can also be a possibility. Or importing the sail as a 3D-dwg-file?
6 Posts No Rating |
thx Mr. GG
It helps a bit. I'm just not sure how to draw 2 connected lines as a profile. Can you delete one after you finished? Or you need to make a void afterwards?
I got some crazy architecture modelled in Rhino which I want to bring into Revit to see if the program can take really complex shapes. I'm not yet convinced that Revit can do these things easily. Maybe you have a better idea?
admin
Use a blend... with curved profiles. Hopefully that will get you going in the right direction
Hiroshi Jacobs
The Catholic University of America |
6 Posts No Rating |
cool, it works. But the blend needs to work with closed lines
got to try some more things to see how i can apply materials to it and maybe get some windows or doors in.
Lets say that I have a curved wall in 2 directions. Is it possible to make a curtain wall of it? Structurally spoken, it should be possible, its just very hard.
twisted/slope/curve roof |
Thu, Oct 19, 2006 at 7:26:05 PM
twisted baluster family |
Tue, Aug 2, 2005 at 8:17:00 AM
not sure..... |
Thu, Feb 26, 2009 at 5:49:30 AM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects |
Fri, Oct 12, 2012 at 7:31:59 AM
How to create a twisted beam of light? |
Sat, Sep 17, 2016 at 6:56:20 PM
Members: | 2115045 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
