73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Railing issue
Tue, Jun 12, 2018 at 5:39:31 AM | Railing issue
madziairm
Hi everyone,
I have an issue with a wall hosted (flat) railing. All model was made in R2017 but I had to upgrade it to R2018 and after this my railing went crazy (please see attachments). It's about this small diagonal part of the path. In R2017 everything works fine. Changing directions cause other problems with the railing.
Thanks in advance,
M.
Tue, Jun 12, 2018 at 2:57:32 PM | Railing issue
sllana
5 Stars: 2 Votes
I have no idea, but i would try something like export it as a group and then inserting it into the upgraded model.....and see what happens
Wed, Jun 13, 2018 at 1:29:45 AM | Railing issue
Elnazer2
4 Stars: 5 Votes
i would try imitating the old type with a similar new one created on RVT 2018 if its a bug then everything will work fine
Wed, Jun 13, 2018 at 2:15:02 AM | Railing issue
madziairm
Thanks guys!
I managed to work around this issue: basically changed direction of the path, then part of the railing created a step and went down but I edited it and used as a host top rail with bottom offset and somehow it works.
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:23 PM
stair railing transition at landing issue (2015)
Wed, Sep 16, 2015 at 9:29:51 AM
Railing Turns Into Transparent Red
Thu, Aug 10, 2017 at 2:06:42 AM
Railing Issue with Revit 2015
Thu, Apr 7, 2016 at 7:38:08 AM
railing at post issue
Fri, May 22, 2009 at 9:40:41 AM
Page generation time: 0.4098
