64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> LINE IN VIEW TITLE
0 Posts No Rating |
WHAT CONTROLS THE LINE SHOWING OR NOT SHOWING ON INSERTION. hOW DO i TURN IT ON WHEN IT DOESNOT SHOW - VER 2017 -
TTHANK YOU - BYRON
![4 Stars: 19 Votes](/images/stars_4.gif) |
It depends on how the family has been created. Standard View Title families have a parameter to control tthe visibility of the line. If yours doesn't, you can edit the family and give it a visibility parameter.
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
as tim123 said all the families will have a default parameter in the type which is show the Show Extension Line to control that line but some custom parameters people add an extra line inside the familiy itself so if you have any issues with that just go and check the view title family and wheither add a visibility parameter for it you need it or delete it
Best of luck
Control Line in View Title Tag |
Mon, Jun 11, 2018 at 7:45:48 AM
View Title Extension line |
Mon, Apr 23, 2007 at 6:38:22 PM
View Title Line Thickness |
Thu, Jan 24, 2008 at 1:42:39 PM
Deleting View Title Extension Line. |
Thu, Dec 27, 2007 at 10:06:05 AM
View Title drawing scale associated to the right and moving with the line |
Wed, May 9, 2018 at 5:41:08 PM
Members: | 2016908 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
