93 Users Online (91 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> pipe tee size
Thu, Jun 7, 2018 at 3:50:09 PM | pipe tee size
vinnygolfer
4.5 Stars: 4 Votes
Hello all,
i have worked in Revit since 2008 and still can't figure this one out. can you set a parameter on the tee that would size the tee for the largest pipe size connected to it, and automatically change if you make changes to the pipes. for example if you have a 1" pipe that you branch off a 3/4", the tee would be 1" with a reducer on the 3/4" pipe side. if you change the supply size to say 1-1/4" the tee will not change it will just put a reducer on the side that got larger, and you have to manually change the tee to a 1-1/4" tee. i would like it to be automated. there are times that we have this on hundreds of tees on one project.
Try to learn at least one new thing every day
Red tee
Thu, Dec 30, 2010 at 12:09:30 PM
Ductile Iron Flanged tee's and Flanged transition
Wed, Dec 31, 2008 at 1:07:35 PM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:07 AM
How to get pipe fittings to appear as simple pipe lines?
Thu, Mar 20, 2014 at 4:40:09 PM
12
Revit2013 - 'Pipe Size' Parameter Can't Be Used
Mon, Jun 10, 2013 at 2:25:35 PM
Page generation time: 0.4018
