67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Updating Multiple Project Parameters at once.
Wed, Jun 6, 2018 at 8:32:54 AM | Updating Multiple Project Parameters at once.
JBRADLEY
Using Revit 2018.  Is there anyway to "Push" Parameters into multiple projects at once?  I work at a firm that maintains multiple prototypes and would like to be able to update a (mm/dd/yy) field located in the project Title Block of each Revit file.  Using the CTC BIM Manager Suite, I can push parameters to multiple Families files, but not to Project Files.   Basically, before I upload all of my Revit models to the client, I want to be able to quickly update the mm/dd/yy without having to open, save, and close each revit file.   I am new to Dynamo, and not sure if it would be possible to do it using that?  Any suggestions would be helpful.  Thank you.
Updating materials in family editor not updating project.
Thu, May 16, 2019 at 12:22:47 AM
Updating Central file (multiple users)
Fri, May 15, 2009 at 11:44:34 AM
Family Parameters Not Updating on Reload
Mon, Jan 4, 2016 at 4:02:16 PM
Multiple project north[s]
Fri, Apr 15, 2016 at 3:15:12 PM
11
Shared Parameters - Schedules multiple parameters one column?
Thu, Oct 4, 2012 at 7:10:21 AM
Page generation time: 0.8108
