Forums >> Community >> The Studio >> revit 2019
Again disappointing new features
Edited on: Fri, May 25, 2018 at 9:01:51 AM
Edited on: Fri, May 25, 2018 at 1:42:14 PM
no suprises there. 13 years of Revit use and still I have to select "multiple" every time I reopen Revit.
Except for the "OR" in filters. At last they did it.
REVIT (and pretty much all autodesk products) is released the first of April every year for 'share holder' reasons only and has nothing to do with helping the customers. For customers it's just a pain in the curse. It has nothing to do with a 'new release or features' Whether there are changes or updates it's released like an egg timed by April 15th every year and simply includes anything new that time. You can stop being excited about new REVIT releases cuz it's never going to happen.
Here is the way to set copy “Multiple” in your template.
1. Open the template, not a new project from the template.
2. Select an item, then copy, check the box for “Multiple”.
3. Copy to any place, then delete that copied item. Which means that you haven’t change anything to your template, except that “Multiple” box checked.
4. Save the template.
revit 2019 and revit 2024 same pc |
Tue, Sep 19, 2023 at 7:54:32 AM
Revit 2019 - RPC not installing |
Tue, Nov 6, 2018 at 4:08:52 AM
2019 snap indicator color |
Mon, Jun 3, 2019 at 2:54:06 PM
Revit 2019 - Steel Plate question |
Wed, Sep 25, 2019 at 1:18:30 PM
converting revit sheet to image |
Sat, Mar 23, 2019 at 10:44:31 AM
Members: | 2098160 | Objects: | 23164 | Forum Posts: | 152291 | Job Listings: | 3 |
