50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Shared Parameter In Annotations
Tue, May 22, 2018 at 5:44:21 PM | Shared Parameter In Annotations
Bennydablade
Bennydablade Avatar
I am trying to create an annotation that will read the title block parameters I have set up in each project. For instance, i have created title block parameters that you fill out in project information and they populate on the title block, i.e. lot, block, address etc. We also put that information on the site plan in a notation. I would like for that notation to read the title block parameters. If I change the family category to title block, then it screws with how i can use it in the project, but the parameters work. If it is in another category (generic annotation) then the parameters don't work properly. I have attached the annotation family as well as our title block family. Any help would be great.
DO or DO NOT, There is no try!
Thu, May 24, 2018 at 6:11:57 AM | Shared Parameter In Annotations
Bennydablade
Bennydablade Avatar
Found this post after continued searching on the forums. Thanks to @WWHUB for the solution.
Tags not "dumb" annotations.
https://www.revitcity.com/forums.php?action=viewthread&thread_id=24945
Shared Parameter File Deleted
Mon, May 19, 2014 at 11:30:32 AM
Cannot Locate SHARED PARAMETER FILE!
Tue, Oct 7, 2008 at 3:16:49 PM
Genereic annotations and shared parameters.
Fri, Aug 19, 2011 at 6:54:23 AM
Shared Material Between Families
Mon, Aug 31, 2015 at 11:21:41 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:25 PM
Page generation time: 0.8830
