68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> wall sweep returns
![3.5 Stars: 5 Votes](/images/stars_3.5.gif) |
Is there a way to continue wall sweeps around the returned end of a wall. I can make it return on itsel, but not around the end of a wall.
33 Posts No Rating |
Put the sweep on the adjacent wall in the same manner you did on the wall with the sweep shown in your image. You can then stretch, shrink, or return that sweep however you need. The sweep is put in by default from end to end, but can be modfied in plan view.
There is no adjacent wall, it is the end of a single wall that I want to wrap the cornice around.
Now I'm on the same page.
That's even easier. Once you've changed the return on a sweep so it cut back on itself (the way you already have, you can drag the size of the return independent of the corner. In 3D view click on the object once so it's active. Then drag the little dots that define that objects extents. See image.
Excellent! I noticed that you have to "change sweep returnts", then select the end to make the dots show up. In some cases, I had to delete the wall sweep and start over, as the dots wouldn't show up no matter what I did. Quirky, but it works, thanks.
Stacked Wall Sweep Returns (RAC 2008) |
Mon, Nov 5, 2007 at 8:49:08 AM
Brick wall sweep surface pattern??? |
Wed, Sep 14, 2011 at 9:07:27 PM
Window Sill Returns? |
Wed, Feb 18, 2009 at 10:58:57 AM
Wall Sweep Return Ends |
Sun, Sep 11, 2005 at 11:55:27 AM
Masonry Pilasters and Wall Returns |
Sun, Mar 4, 2007 at 5:15:45 PM
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
