50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Revit Boxed Dimension
Hi all,
Probably a novice question but one that has bugged, can anyone tell me how to make a boxed dimension style for "overall" setouts.
Thanks
This kind of dimension and question has never shown up here on RC in all the years I have been a monitor. There is no way to do this with conventional Revit.
Intertersting, because the screen shot was taken from a Revit job.
Maybe an fill box over? Unlikey as you can't snap to the dimension and these look in perfect allignment.
That could be done using a detail line based family that uses a label to report the length.
See attached family (Revit 2016)
If the one he has were a detail line based family, it would report as such rather than a dimension. In either case, this will work as a solution.
Mate, you nailed this! Well done, this is exactly what I was chasing. Can't thank you enough
keynote legend boxed keynote tag |
Fri, Jul 18, 2008 at 9:29:57 AM
Boxed in Eave Roof |
Thu, Jun 14, 2012 at 11:14:54 AM
Boxed End Bottom bearing Steel Joist |
Tue, Feb 21, 2012 at 11:38:27 AM
Boxed Text In Dimensions |
Wed, Oct 29, 2014 at 10:01:21 AM
Activate Dimension |
Tue, Dec 13, 2011 at 12:53:44 PM
Members: | 2056669 | Objects: | 23074 | Forum Posts: | 152327 | Job Listings: | 3 |
