84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> plan region
Thu, May 3, 2018 at 9:42:26 AM | plan region
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
has anyone had an issue where a plan region affects the the main view range. i have a room that has a plan region set at 6'6 and i lose my room tag. it only happens to one room other rooms that are set up the same are fine. the room iteslf seems to disapper. i think tht has some thing to with it beeing cut by the plan region at 6'6 and the main view at 4'6 and it moves it higher because of the plan region.
Thu, May 3, 2018 at 4:53:08 PM | plan region
Are you sure your rooms are not too short.
Plan Region
Fri, Jul 21, 2006 at 4:23:11 PM
Plan Region problem - walls/slabs/framing displaying outside the region boundary
Tue, Jun 23, 2009 at 4:46:33 PM
RA2008 Plan Region Removes Wall Detail Outside of Region [ 1 2 ]
Thu, Sep 18, 2008 at 8:19:26 AM
16
Plan region not showing lines in detail view [ 1 2 ]
Mon, May 11, 2015 at 11:17:49 AM
15
PLAN REGION PROBLEM
Wed, Sep 10, 2014 at 11:15:23 AM
11
Page generation time: 6.9904
