77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Reference tag on on same view?
Wed, May 2, 2018 at 11:25:28 AM | Reference tag on on same view?
alexcolodner
So i've been trying to figure out a way to accomplish this for what feels like EVER.  Any ideas or suggestions would be helpful.
I do a lot of system connectivity diagrams.  I often have devices that need to connect to another device on a different sheet OR elswhere on the same sheet (but there is no visual way to draw a conection between the two.  I use tags with the device name and sheet number that it should be connecting to (see attached image).
Is there a way to make these tags "smart"?  You can see now that I just have placeholders for the sheet numbers and then when i finish all the sheets I go back and tediusly fill them in.  If I delete a device i need to track that through all the tags.
I've tried view reference tag/parameter but you cant place a reference to the same sheet.  I'm happy to ammend the device family to add identifiers to make this work.  Also, could this be done in dynamo.
View Reference
Thu, Dec 26, 2013 at 11:54:57 AM
Multi-view Elevation - Reference SIM
Fri, Mar 9, 2012 at 8:40:42 AM
Detail reference tags
Tue, Feb 7, 2017 at 11:22:08 AM
Detail callout tag... for 2010
Wed, Nov 11, 2009 at 11:58:51 AM
detail callout tag, multiple times on the same view
Thu, Oct 8, 2009 at 1:16:25 PM
Page generation time: 1.5603
