90 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to cut mass conceptual divided surface
Sun, Apr 29, 2018 at 10:03:19 AM | How to cut mass conceptual divided surface
unnbe
Hi everyone,
In my project I've created a mass conceptual surface, dotted by cylindrical components. Well, now I would "open" a window within this surface... How should this be possible? Cut Geometry doesn't work...
The screenshot attached shows the yellow cutting geometry that I would it may cut the dotted surface...
Mon, Apr 30, 2018 at 9:15:59 AM | How to cut mass conceptual divided surface
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Cut geometry would cut partially through one or more of the cylindrical components which is probably what you dont want.
Can you give each of the cylindrical components the parameter option to turn it invisible, then you just select one or more and hide them.
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
Replacing a Conceptual panel in a Mass Family
Mon, Dec 19, 2011 at 9:38:50 AM
Adding Material to Divided Surface
Thu, Apr 17, 2014 at 10:40:12 AM
pattenrned curtain system revit 2010
Mon, Aug 31, 2009 at 5:15:28 PM
Issue with Dividing Surface for conceptual mass
Fri, Nov 11, 2011 at 12:45:47 PM
Page generation time: 0.7108
