77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Base Plate with Grout ,anchor bolts and nuts.
Tue, Apr 24, 2018 at 8:54:45 PM | Base Plate with Grout ,anchor bolts and nuts.
1bchristian
I have downloaded a beautiful base plate with grout, anchor bolts, and nuts but when I open it. It requires an upgrade to 2018. When it does it wans me and deletes the nuts. Can anyone help with a trick or how to fix this? I am new to Revit. Thank you - Byron
Thu, Apr 26, 2018 at 3:32:19 AM | Base Plate with Grout ,anchor bolts and nuts.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Could be a number of reasons to be honest.
Maybe the nuts have a parameter associated with them that allows the user to turn them off.
Maybe the nuts are child familys within a parent family and the nut family is corrupted or causing parametric clashes so it does not load in after the upgrade.
Upload it to here and I'll take a wee look.
Sun, Apr 29, 2018 at 8:25:07 AM | Base Plate with Grout ,anchor bolts and nuts.
1bchristian
This is the upload
Attaching a footing to a column with a base plate nested into the footing family
Thu, Jul 11, 2019 at 12:23:42 PM
Column Base Plate Nested Family - GCS Visibility
Sat, Feb 21, 2009 at 9:17:59 AM
How to make anchor bolts group??
Sun, Jan 31, 2016 at 9:22:24 PM
Column base plate tag units display.
Mon, Nov 17, 2014 at 2:24:40 PM
MATERIAL NOT TRANSPARENT.
Thu, Dec 15, 2016 at 10:18:05 AM
Page generation time: 0.4043
