123 Users Online (122 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Can't Constrain
Thu, Apr 19, 2018 at 11:44:23 PM | Can't Constrain
GeoAce
Wondering if someone can help me?
I'm drawing a light fixture (hanging pendant type) with a power cord that has a slight bend on a differant Work Plane then the rest of the power cord and I cannot constrain that curve. When I "flex" the drawing curve stays stationary but the rest of the fixture can be moved up or down! Please see my attached Snap Shots. Can anyone give me some advice how to resolve this issue? thanks all
Thu, Apr 26, 2018 at 3:46:54 AM | Can't Constrain
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
I've never modelled power servicing to lights as I would consider it over-detailing.
But if I had to do this, I would be thinking along these lines.
What elements are fixed in size, what elements need to increase/decrease in size parametrically and what elements are associated with other elements.
In my mind, your 2 grey light elements and the curved elements of the power cord are all fixed in size and should be locked in place to each other. Use references lines to do this. The power cord descending down and the support cables descending down will increase in length to suit your light suspension height, so they both should be locked to reference line A at the top ( I assume this is your ceiling plane) and the reference line B at the bottom ( A fixed distance above the lighting fixture). A distance parameter between A & B gives you height flexibility. Ref Line B should link to the lighting elements and cables, such that if B moves, they all move with it.
So step 1, setup ref lines A & B and its length parameter
Step 2. Setup ref lines below B that are locked together.
Step 3 model cables/services between A & B.
Step 4 model light elements/cable fixings/power cables below B and lock them to the ref lines.
This should resolve the Z plane.
In plan, I expect a central ref line will be necessary and all elements should be locked to it.
Fri, Apr 27, 2018 at 12:26:20 AM | Can't Constrain
GeoAce
You've layed this out wonderfully but I don't understand what you mean in step 3 - model cables/services between A & B.?
The bends in the cable are done with a spline and then I used sweap function isn't that a model?
I greatly appriciate your help.
Thanks
Parameters that don't act to constrain
Fri, Feb 2, 2007 at 10:37:02 AM
Cant constrain Revit families inside of building
Wed, Dec 10, 2014 at 2:09:38 PM
Strange "constrain" issue when copying.
Thu, Feb 25, 2016 at 6:52:02 PM
how can i use a terrain made to be a base constrain!!
Fri, Jan 28, 2011 at 9:02:14 AM
trouble with contraints
Thu, Apr 19, 2007 at 6:11:25 PM
Page generation time: 2.0611
