56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> create a plumbing fixture count schedule
Fri, Apr 6, 2018 at 12:54:26 PM | create a plumbing fixture count schedule
elizabethpetermathew
Hello,
I would like to create a plumbing fixture COUNT schedule based on occupant load and area. How do I insert these formulas or math into my schedule parameters, when i Create a new field?
Thank you in advance.
Mon, Apr 9, 2018 at 10:06:56 AM | create a plumbing fixture count schedule
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
TBH I'm not too clear what you are asking but if you have a Revit model and you placed numerous plumbing fixtures within that model, then you can create a schedule that lists all of those plumbing fixtures as follows:1) View Tab - Create Section - Schedules Tool Dropdown & select Schedule/ Quantities.
2) In New Schedule window that appears, Select Plumbing Fixtures ( Note: The plumbing fixtures you placed in the model should be a plumbing fixture family category.)
3) In Schedule Propoerties window that appears, go through the available fields ( parameters) on the left hand side and move them across using the arrow in the middle.
4)You can create calculated values using the Fx button in the middle also.
5) Set remaining tabs to sort and filter your parameters.
Mon, Apr 9, 2018 at 5:55:37 PM | create a plumbing fixture count schedule
readyroth
2 Stars: 1 Votes
I think the OP is looking for a schedule that will calculate the required # of plumbing fixtures based on areas/occupant load.   Are you using schedule now to calculate the occupant load for the building based on areas (i.e. from rooms)?  If so, I think you could extend that to also calculate the required plumbing fixtures.  A little complicated to explain here...
Tue, Apr 10, 2018 at 1:08:33 AM | create a plumbing fixture count schedule
tim123
4 Stars: 19 Votes
When you create your schedule, there is an option to 'Select available fields from:'.  There you can select other fields, such as 'Room' or 'Space' parameters rather than just the 'Plumbing fixtures'.
Plumbing Fixtuer Tags
Wed, Feb 4, 2015 at 1:41:01 PM
Plumbing Fixture Schedule
Thu, Jan 30, 2014 at 10:36:01 AM
Light fixture not appearing in fixture schedule
Thu, May 7, 2015 at 7:26:01 AM
Plumbing Fixtures Schedule
Sun, Sep 23, 2007 at 9:52:10 PM
Plumbing fixture and snapping to corner
Fri, Apr 4, 2008 at 2:46:41 AM
Page generation time: 1.1263
