65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Source for a hatch pattern
Wed, Apr 4, 2018 at 3:41:28 PM | Source for a hatch pattern
Warchitect
4 Stars: 5 Votes
I've taken a look at the downloads but can't find a hatch pattern that is for a horizontal lines spaced 6", then 3", then 6" etc alternating. My clients want to see a horizontal board pattern where that is going on. alternating 6" and 3" siding.
the vertical "board and batten" pattern is kinda close, but of course 90 degrees off and spaced diff.
Does anyone know a place to get that? im not too versed in writting the pattern code.
Thu, Apr 5, 2018 at 1:03:58 AM | Source for a hatch pattern
tim123
4 Stars: 19 Votes
If its a model pattern then the pattern can be rotated by tab selecting an individual line and rotating it.  You can also find the .pat file and look for that pattern and adjust the spacing.  Alternatively, I attach an explanation for creating a pattern from scratch.
Thu, Apr 5, 2018 at 9:33:57 AM | Source for a hatch pattern
readyroth
2 Stars: 1 Votes
It's a pretty simple pattern.  I think it will be like this:
*Siding, 6in and 3in;%TYPE=MODEL0, 0,0, 0,90, 0,6, 0,9
I think you need to make sure the .pat file name is "Siding", or if you name it different make the first line in the code match. That will start with a 6in board, then a 3in and so on....  Hope it helps.
Thu, Apr 5, 2018 at 12:47:49 PM | Source for a hatch pattern
Warchitect
4 Stars: 5 Votes
THanks a lot for the help.
the illustrated explanation is too confusing for me.
and the pattern noted down doesnt work. Just makes  big lines. I have no idea how to fix that.
also, the pattern doesnt load unless you delete the 6 and 9 line from it. then it makes a simple 7'6 lines...
I dont know how to fix that. if someone who "knows" cant, why would revit think I can? :-(
I really appreciate the help. But there is no solution here.
Thu, Apr 5, 2018 at 1:22:21 PM | Source for a hatch pattern
readyroth
2 Stars: 1 Votes
Sorry.... the line breaks dropped from the pattern def in my previous post.  Try the attached... i tested it here and it works.
The hatch codes seem confusing at first, but simple patterns are easier than you think when you get into it.
Let me know if it works for you.
Thu, Apr 5, 2018 at 1:27:32 PM | Source for a hatch pattern
readyroth
2 Stars: 1 Votes
This file was pretty useful to me explaining how to make the hatch patterns
Thu, Apr 5, 2018 at 2:38:48 PM | Source for a hatch pattern
Warchitect
4 Stars: 5 Votes
WOW Thanks!
that pattern worked. I tried to match the page breaks earlier, but I couldnt do it.
Thanks also for the PDF explanation.
Michael
Stone Hatch Patterns - Looking for a good source.
Sat, May 4, 2013 at 4:59:24 AM
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Hatch 22- Curve Pattern
Wed, May 30, 2018 at 4:07:07 PM
Page generation time: 0.6285
