111 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Flipping a Detail Component with the Space Bar
Wed, Apr 4, 2018 at 12:24:16 PM | Flipping a Detail Component with the Space Bar
mark7321
I'm using Revit 2018. When I place a detail component steel angle the "side" type of profile I can't flip the angle using the space bar so the leg of the angle will be facing away from me giving me a hidden line. Anyone know why??
Thu, Apr 5, 2018 at 8:33:43 AM | Flipping a Detail Component with the Space Bar
aandr001
4.5 Stars: 6 Votes
Hi Mark,
This component does not have a "back" side so to speak.  You can however edit the family, select that particular line and make it a hidden line instead of a solid line and then load it back into your project.
Why some 2 letter shortcuts require enter or space bar and others don't
Tue, Dec 31, 2013 at 10:39:20 AM
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:16 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:46 AM
space bar not rotating components
Tue, Jan 8, 2008 at 5:27:00 PM
Component rotate
Tue, Feb 8, 2011 at 10:55:47 AM
Page generation time: 1.2000
