54 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Lines showing through material
created curtain wall to simulate raised seam metal siding, the 2x4 purlins behind are showing through on all elevations(2d/3d) there are no transparancies and the material is a solid. I think its just because the material is too thin? When you zoom in it does not show through at all. Does anyone have a work solution for this?
I forgot to add this is Revit 2016 version
You would have to move your material out from the purlins.
Did you look at other solutions? Using a material is far superior to what you did.
In shaded View walls/roofs are showing material and lines behind them |
Tue, May 28, 2013 at 9:35:44 AM
material not showing in render.....plz help |
Sat, Jul 2, 2011 at 5:44:27 AM
Object Material Not Showing |
Wed, Dec 9, 2015 at 9:05:15 AM
Dashed lines in families are showing as solid lines in project |
Thu, May 10, 2012 at 8:38:48 AM
Material showing differently in 3D view |
Thu, Jun 12, 2014 at 12:15:48 PM
Members: | 2017311 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
