Forums >> Revit Building >> Technical Support >> 6x12 Herringbone Pattern .pat file help
I'm trying to create a 6x12 herringbone pattern using a 2x6 as an example:
*HerringBone 2x6, brick herringbone
;%TYPE=MODEL
45, 0, 0, 2, 2, 6, -2
135, 1.414, 1.414, 2, -2, 6, -2
Here's what I came up with, but it doesn't work:
*HerringBone 6x12, brick herringbone
;%TYPE=MODEL
45, 0, 0, 6, 6, 12, -6
135, 4.242, 4.242, 6, -6, 12, -6
Advice on what I'm doing wrong, maybe the sqaure root equation is off?
I made one for you using hatchkit.
*6x12 Herringbone,6x12 Herringbone
;%TYPE=MODEL
-45,8.4853,8.4853,18,6,12,-12
45,0,0,18,-6,12,-12
-45,4.2426,4.2426,18,6,6,-18
45,12.728,4.2426,18,-6,6,-18
*edit* formatting
Edited on: Tue, Apr 3, 2018 at 11:07:49 AM
The math changes cuz the original pattern is a 1:3 ratio, yours is 1:2.
I've always found it much easier to make the pattern orthogonal (not at 45 degree)... makes the numbers much simpler and rational. Only means you have to rotate the pattern in your model. The other pattern will also probably start to get off if the area is large enough.
Here's one i made for a 3x6 pattern. I think it works. You can probably just double the numbers to make 6x12.
Hope it helps.
This is from HatchKit's herringbone generator, portion of its brick and tile wizard:
; Written by HatchKit for Revit
; HatchKit for Revit (c)1990-2017 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2018-05-02
;-Time : 10:59:59
;-HatchKit Version : 3.1.10.2733
;-HatchKit Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*Herringbone6x12,LEFT-HAND 12"x6" weave=1/1
;%TYPE=MODEL
-45,-4.2426,21.213,6,6,18,-6
45,0,0,6,-6,18,-6
hth,
Hugh Adamson
Edited on: Tue, May 1, 2018 at 10:41:20 PM
Hugh Adamson
www.hatchkit.com.au |
6"x48" Herringbone .pat revit file help |
Tue, Jul 21, 2015 at 10:09:09 AM
4" X 24 " orthogonal Herringbone Pattern .pat |
Sun, Oct 20, 2019 at 7:46:08 AM
How did this .pat Code number come about? |
Thu, Jan 11, 2024 at 7:02:47 PM
Basket Weave Heringbone Hybrid Pattern HELP! |
Thu, Apr 5, 2018 at 1:07:31 AM
Pattern (.PAT) Files |
Mon, May 3, 2021 at 4:51:05 PM
Members: | 2097907 | Objects: | 23164 | Forum Posts: | 152288 | Job Listings: | 3 |
