90 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2018.2 Print to PDF Turning Curves into Polygons
Wed, Mar 28, 2018 at 6:56:15 PM | Revit 2018.2 Print to PDF Turning Curves into Polygons
bitslap
I use Bluebeam 2017 but I have tried a number of exporters including the DWF export.  When I open the file, my curves have all been turned into polygons.
What am I doing wrong?
Wed, Mar 28, 2018 at 8:17:14 PM | Revit 2018.2 Print to PDF Turning Curves into Polygons
bitslap
I have played with the settings extensively and can only put it down to bad vector plotting from Revit.
I could be wrong, but in my opinion you are still much better off printing shaded views to raster.
I hope someone has a better solution that elegantly plots shaded views in vector format.
Thu, Mar 29, 2018 at 7:31:22 AM | Revit 2018.2 Print to PDF Turning Curves into Polygons
Revit will automatically print shaded views in raster format.... after all, there are no lines in shaded areas.
Mon, Apr 2, 2018 at 7:53:41 PM | Revit 2018.2 Print to PDF Turning Curves into Polygons
bitslap
I have semi-transparent trees over floors with a shade and a surface pattern. When visual style is set to 'consistent colours', everything prints as a vector - just a very bad one.
Tue, Apr 17, 2018 at 12:30:40 AM | Revit 2018.2 Print to PDF Turning Curves into Polygons
bitslap
I just wanted to post an update that Revit 2019 is significantly better at this process. I still get some polygons but semi-transparent materials overlayed are showing really well as vectors.
I want to print the whole document to pdf In one step
Wed, Dec 8, 2004 at 7:23:01 AM
Wall Solid Fill Cut Pattern Jagged on PDF
Fri, Apr 3, 2015 at 10:36:33 AM
Physical Print Quality of PDF's Produced from Revit
Tue, Apr 23, 2013 at 9:49:55 AM
Font will not print to pdf file.
Wed, Aug 19, 2020 at 9:16:24 AM
Print to PDF crashing
Tue, Apr 6, 2010 at 3:55:56 PM
Page generation time: 3.1348
