126 Users Online (125 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> spot elevation symbol size
Fri, Mar 23, 2018 at 8:53:56 AM | spot elevation symbol size
sllana
5 Stars: 2 Votes
Hi, is there a way to change the size of the circle of the target symbol? when you edit the family it is only the inner solid forms what you can edit but not the circumference itself. I tried to fake it by doing it with regions but original remains the same.
Thank you
Edited on: Fri, Mar 23, 2018 at 4:33:52 PM
Fri, Mar 23, 2018 at 1:03:30 PM | spot elevation symbol size
PedjaCh
When you edit the familly, go to Familly Types -> Radius
Fri, Mar 23, 2018 at 4:43:23 PM | spot elevation symbol size
sllana
5 Stars: 2 Votes
No, it was easier, i just had to turn "on" the visibility of lines, but the issue is that the Visibility/graphics button in the symbol family editor, is not in the instance properties window but only in the ribbon, and that is why i hadnt find it.
Target size of Spot Elevation (Revit Architecture 2008)
Wed, Aug 6, 2008 at 9:43:56 AM
Spot elevation target symbol
Wed, May 27, 2015 at 5:09:17 PM
Target size of Spot Elevation (Revit Architecture 2008) 2
Thu, Dec 18, 2008 at 11:21:25 AM
Spot elevation - symbol line greyed out
Tue, Jan 17, 2012 at 3:44:56 PM
Spot elevation symbol [ 1 2 ]
Mon, Dec 1, 2008 at 10:10:59 AM
16
Page generation time: 0.8799
