56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dimension strings not adding up to the total length dimension string (2017)
Thu, Mar 22, 2018 at 12:48:21 PM | Dimension strings not adding up to the total length dimension string (2017)
ledgewood33
i have a string of dimensions that do not add up to the total length dimension string. there is a dimension in the multi-string that is 1/256" off. i have my rounding set to the 1/256" so this way i get a true dimension. i would like to know if there is a fix for this? not necessarily a work-around. i am attaching a revit file that shows this issue.
Fri, Mar 23, 2018 at 1:33:59 AM | Dimension strings not adding up to the total length dimension string (2017)
tim123
4 Stars: 19 Votes
Your dimensions are only approximate.  Even though you have set the dim rounding to the finest level, it calculates it to the nearest 255/256.  When I take your file and dim it in millimeters, it also does not tally, but when I set the accuracy to 2 decimal places, the dimensions add up.
Adding a dimension to a dimension string...
Wed, Jul 10, 2013 at 3:42:10 PM
Dimension String
Wed, Nov 22, 2006 at 3:05:16 PM
partially obscurred dimension string
Mon, Oct 29, 2007 at 10:45:14 AM
Dimension String Doesn't Equal Overall Dimension
Wed, May 27, 2009 at 2:33:50 PM
locking long dimension strings
Mon, Apr 25, 2011 at 11:43:36 AM
Page generation time: 0.3974
