46 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Schedules - Cell Height Adjustments
Tue, Mar 20, 2018 at 1:55:48 PM | Schedules - Cell Height Adjustments
lchlimou
Hello. I upgraded a project from 2015 to 2017. The room schedules are difficult to read now in 2017. Cell heights are not tall enough to fit the entire text, regardless of the text size (I've made text smaller/larger and it appears the same). The resize option in the ribbon (under Modify) is greyed out, so that is not an option. It looks fine on a sheet, but I can't edit the information in a sheet view, I've always done that in a schedule view. I've attached an image to help clarify.
How can I adjust the cell height in the schedule view?
Thank you.
Tue, Mar 20, 2018 at 2:22:09 PM | Schedules - Cell Height Adjustments
Did you follow this in your HELP?
Tue, Mar 20, 2018 at 3:07:47 PM | Schedules - Cell Height Adjustments
lchlimou
I did look into that - the text size does not affect the height of the cell, unfortunately. The cell still covers part of the text regardless of the text size.
Tue, Mar 20, 2018 at 6:48:06 PM | Schedules - Cell Height Adjustments
Have you got all of the updates installed?
Wed, Mar 21, 2018 at 10:23:53 AM | Schedules - Cell Height Adjustments
lchlimou
Yes - I just installed the program a few days ago so all updates should be installed. I am on a trial version - maybe it has something to do with that? Other graphical elements have been out of whack, but fixable or workable - such as my navigation bar and project browser showing up blank and other similar things.
Wed, Mar 21, 2018 at 11:53:57 AM | Schedules - Cell Height Adjustments
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Are you running this on a 4K monitor as Revit doesn't get along well with them.  This looks like a similar display error.
Wed, Mar 21, 2018 at 12:40:10 PM | Schedules - Cell Height Adjustments
lchlimou
Nope - not a 4k monitor :/
Door Schedules - Changing Cell Font to Mark Further Review
Tue, May 22, 2018 at 8:52:58 AM
Fomatting Row Height in Schedules [ 1 2 ]
Fri, Feb 28, 2014 at 7:18:29 AM
15
Exporting schedules to Excel with multiple lines in a cell
Thu, Jan 24, 2013 at 9:55:30 AM
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:17 AM
Curved Cell Beams
Thu, Dec 11, 2008 at 11:00:17 AM
Page generation time: 0.3372
