37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Reference Plane in detail component
Mon, Mar 5, 2018 at 2:51:31 PM | Reference Plane in detail component
CKirivong
I'm trying to add a reference plane to a Revit out of the box 2D detail component, specificially the CMU section. I keep getting the following error message: "None of the created elements are visible in Floor Plan: Ref. Level View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
Has this happened to anyone else? Anyway to get the reference plane to show up? Thanks!
Mon, Mar 5, 2018 at 3:38:15 PM | Reference Plane in detail component
You are in the family editor, correct?
What view and what process?
Mon, Mar 5, 2018 at 5:17:04 PM | Reference Plane in detail component
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
type VV -> annotation categories tab -> put a check mark in the window next to 'show annotation categories in this view' -> click OK
Mon, Mar 5, 2018 at 8:55:45 PM | Reference Plane in detail component
CKirivong
That worked! thank you!
Vertical line-based detail component?
Tue, Jun 3, 2014 at 2:30:53 PM
Detail Component Visiblity in Sections
Fri, Aug 14, 2009 at 3:35:28 PM
Locking Detail Curve to Reference Plane for Paramterizing (RAC 2012)
Tue, Mar 20, 2012 at 12:17:36 PM
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
Page generation time: 0.8965
