39 Users Online (37 Members):
Forums >> Revit Building >> Technical Support >> Current 3d PDF converters?
Does anyone have any up-to-date 3d PDF converter recommendations? I've found a few threads and general google info but a lot of the reviews I've seen are several years old. So if you have a recommendation I'd love to hear it!
Thanks!
Your question is not clear to me.
Revit can print to a 3D DWF or a 3D PDF with the correct PDF program..
Sorry, exporting a 3d PDF from within Revit using a 3rd party software. I've used a couple in the past but has been a few years, and I was never terribly happy with the visual results, but functionally was great.
Adobe is still probably the #1 program.
In what manner does a person export a 3d pdf from Revit using Adobe?
https://bim.wikispaces.com/Revit+to+3D+Pdf+-+BIM+Functionality
Great, I'll check it out! It was my understanding Adobe no longer made an extended version that supported this, it's possible I was given bad information though, or simply cannot find it.
Thanks!
From what I've been able to tell, there is no longer an Adobe Pro Extended version, only Adobe DC which is available on the cloud, which does not have the ability to import an ICF file (unless there's some work-arounds you have to do in order to get this to work). Anyone have any other suggestions as to what works for you?
0 Posts No Rating |
There are a vew plugins to export from revit to OBJ and use MeshLab to save as a U3D, you should be able to import that into Adobe.
3D PDF from Revit, Navisworks or 3D DWF |
Tue, Sep 13, 2011 at 9:11:45 PM
11
after revit export to pdf the file is wrong scale |
Sat, Nov 20, 2010 at 10:54:04 PM
Exporting to PDF results in blank page |
Wed, Apr 30, 2014 at 3:24:27 PM
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND?? |
Thu, Nov 4, 2010 at 9:43:22 AM
PDF File Names |
Thu, Apr 7, 2011 at 8:37:37 AM
Members: | 2019209 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
