63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Columns not showing up in elevations??
Tue, May 30, 2006 at 7:34:20 PM | Columns not showing up in elevations??
vnd
3 Stars: 2 Votes
I have been having problems with columns not showing up in my elevations and have not been able to solve this problem for a while. The problem is that for example a 200x200 column shows up as a thick black line in elevation... why?
VND
Tue, May 30, 2006 at 8:37:36 PM | RE: Columns not showing up in elevations??
Nicolas
1 Stars: 1 Votes
You might want to check the detail level of your view. If the detail level is set to "coarse" the columns might only come up as lines! Change the detail level to say "fine" you should be able to see them! Detail level can be edited in the view proterties! You can also change the the visibility of detail level in the column family.
Tue, May 30, 2006 at 11:47:14 PM | RE: Columns not showing up in elevations??
vnd
3 Stars: 2 Votes
Excellent... I knew that!... doh!
VND
Wed, May 31, 2006 at 12:12:35 AM | RE: Columns not showing up in elevations??
Nicolas
1 Stars: 1 Votes
If you edit the column family by selecting the column and pressing the "Edit family" button on the menu bar above! Once in the family of the column, select the column and press the button "Visibility..." on the menu bar above. A dialogue box will come up which is the Family Element Visibility Settings box. Here you can set the element (be the column in this case) to come up on different views such as on Plan/RCP or Front/Back or Left/Right or When cut in Plan/RCP. Tick box if you want the element coming up on any of these view. For the column to come up on all view make sure all boxes are ticked. Further more down the bottom of the dialogue box you can specify the visibility of element according to detail level of the view. If you tick all boxes (Coarse, Medium, and Fine) the element will come up in all detail levels. If you wish to only see the element say in Fine detail level than only tick the Fine box. Your column is most likely only coming up in Fine and/or Medium and not in Coarse. But you view in the drawing (of the building elevation) is set to Coarse (or Medium) detail level. This causes the columns not to appear. Try changing the detail level of the column element in the family to be visiblal in all detail level (including Coarse). Hopfully this will make all the difference!
Wed, May 31, 2006 at 6:18:44 PM | RE: Columns not showing up in elevations??
vnd
3 Stars: 2 Votes
... yes i have now tried your suggestion to change it in the family settings and it works well... thanks very much Nicolas!
VND
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
hidden steel columns showing as solid
Tue, Nov 23, 2010 at 12:18:43 PM
Building Not Showing in North/West Elevations
Mon, Aug 18, 2014 at 11:44:38 AM
Beams not showing in Elevations
Sat, Jul 18, 2009 at 3:13:15 AM
Families that are "behind" cut showing up in interior elevations.
Wed, Jan 23, 2008 at 10:50:16 AM
Page generation time: 0.4877
