Forums >> Revit Building >> Technical Support >> Interior Walls - Wainscot Panels - Revit 2018.2
0 Posts No Rating |
Hello!
I am looking for suggestions on the best way to create a wall type with integrated wainscot panel. My wall has a 4" rubber base sweep, a panel sweep and the chair rail sweep; I need to show the breaks in the panels and as you cannot apparently use a vertical reveal in the wall-type I'm looking for ideas on the best way to model this.
The panels are typically 4' wide, however sometimes the panels are smaller depending on the length of the wall. Currently I am showing the panels by drawing detail lines where the reveals would be which is fine for the elevations, but when I work in 3D to show the client, the panels obviously don't show.
I did try a vertical wall reveal, however despite having the wall sweeps set to cuttable, the reveal does not cut through the panel or rail sweep.
Would love suggestions on the best approach for this.
Thanks!
I would use a face based family with a flexible width.
0 Posts No Rating |
Is that fairly easy to create and setup? If I wanted the architect to create the family, what parameters do I need to give him in order to make it?
Use a face based template.
It will be an extrusion with an instance based parameter to control the width. Another if you need to control the hieght as well. Height should probably be a type based as it would not change as often. The material would be another parameter.
0 Posts No Rating |
Will give this a shot, thanks!
Interior finishes - how appied |
Tue, Feb 5, 2008 at 11:56:09 AM
Revit 2018 - Changing wall fills specific to sheet |
Tue, Aug 29, 2017 at 2:02:44 PM
I cant think of the right word! |
Wed, Aug 15, 2007 at 6:34:56 PM
Brick Wainscot Covers Door and Window Trim |
Thu, Mar 19, 2009 at 1:24:50 AM
Applying a wainscot onto a wall |
Wed, Feb 18, 2015 at 3:52:24 PM
Members: | 2116405 | Objects: | 23194 | Forum Posts: | 152302 | Job Listings: | 3 |
