70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Door and Window Tags in Legends
Tue, May 30, 2006 at 7:18:48 PM | Door and Window Tags in Legends
fordd
I'd really like to tag all my doors and windows in my Legends...the elevation sheet of all the project doors and windows. How is this accomplished?
Mon, Jan 21, 2008 at 7:24:52 AM | Door and Window Tags in Legends
JHanby
3.5 Stars: 3 Votes
I would like to do this also.  Using Revit 9.1.  Is it possible or do you have to make symbols to look like the tags?
Tue, Jan 22, 2008 at 2:57:20 PM | Door and Window Tags in Legends
twhisker
2 Stars: 4 Votes
I have spent hours trying to figure this out with RAC 2008.  It appears the only solution is to create a "dummy" tag that allows you to edit the text on an INSTANCE basis.  Of course the problem is that it is not tied to the same information in the door/window data.  So if you change the type mark of a window in either plan, elevation, schedule, or element properties, it WILL NOT update in the window legend.  This should be at the top of Autodesk's list for next release improvements as it is counter to what Revit is all about.
Revit Architecture 2010
Window & Door Legends
Thu, Sep 10, 2015 at 12:41:55 AM
Window legends
Fri, Dec 31, 2004 at 8:35:40 AM
Creating Window or Door Legends
Wed, May 3, 2006 at 10:30:17 AM
Door and window tags
Thu, Nov 3, 2011 at 8:51:35 AM
Room Window and Door Tags
Thu, Nov 15, 2007 at 9:21:11 PM
Page generation time: 1.0864
