79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Modifying vertical structure in edit assembly
Fri, Feb 9, 2018 at 9:42:53 AM | Modifying vertical structure in edit assembly
omahawildcat
I want to be able to modify the heights of certain elements of a wall assembly. I go into the editing of the assembly and modify and unlock the individual layers of the assembly but when I go to a section and try moving the individual pieces, all of the pieces I have unlocked move together. Is there a way to be able to move each part of the assembly seperately?
Fri, Feb 9, 2018 at 4:27:21 PM | Modifying vertical structure in edit assembly
Your help shows you what you can do.
assembly
Mon, Apr 22, 2013 at 5:03:47 AM
Wall - vertical structure - delete layer
Thu, Jun 3, 2010 at 5:10:53 PM
Revit Can't cleanup walls with Modified vertical structure
Fri, Mar 7, 2014 at 11:34:31 AM
Edit/Customize Assembly Code
Wed, May 5, 2010 at 4:28:31 PM
edit assembly escape key
Thu, Apr 21, 2005 at 11:14:30 AM
Page generation time: 1.3859
