121 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> New Title Page Label Using Project Information
Thu, Feb 8, 2018 at 1:31:47 AM | New Title Page Label Using Project Information
UrbanDesign69
I want to create a label that's linked to the project information (Client Name, Project Name, Project Adress, Project Status) that appears ONLY on the Title Sheet (centered at the top of the page).  I can create a label while in the Titleblock family that links to the project information, but it will appear on every sheet in the set.
When I try to embed a label so that I can toggle the visibility of the label, I cannot define the parameters using the project information.  I can only define it using Name, Discipline, Type & Group.  I was hoping that the Project Info was a shared parameter rather than a system parameter.
Is my only option to write this as text (no label or parameters, not linked to project specific information)?
Thu, Feb 8, 2018 at 9:05:05 AM | New Title Page Label Using Project Information
3.5 Stars: 395 Votes
You need to create a new sheet for this just like you do for your normal sheets.  Save it in your library as ....Title Sheet 24x36? or whatever.
Thu, Feb 8, 2018 at 9:36:21 AM | New Title Page Label Using Project Information
readyroth
2 Stars: 1 Votes
I have a titleblock family with all the standard project info (project name, address, client, etc...) in the banner on the.  I also added large labels at the top center of the page with the same project name and address parameters.  I could assign a visibility parameter to that label (type parameter).  Then in the family, i created 2 family types... one called Cover Sheet and one called Standard, and i set the visibility for the large label to be on in the one type and off in the other.  Works simple.
Thu, Feb 8, 2018 at 11:04:38 AM | New Title Page Label Using Project Information
UrbanDesign69
Is your label on the top center of the title page linked to the system parameter - project information?  from what I've read and videos watched, Is embedding a label or image into the title sheet the only wat to get the visibility toggle checkbox?
Thu, Feb 8, 2018 at 11:04:39 AM | New Title Page Label Using Project Information
UrbanDesign69
Thu, Feb 8, 2018 at 11:04:44 AM | New Title Page Label Using Project Information
UrbanDesign69
Thu, Feb 8, 2018 at 11:41:38 AM | New Title Page Label Using Project Information
readyroth
2 Stars: 1 Votes
Yes.  It is a label linked to the project information.  I think that's what you were trying to do.  See the .rfa... you can see if that helps.  It's pretty straightforward.
Sat, Feb 10, 2018 at 11:54:48 AM | New Title Page Label Using Project Information
UrbanDesign69
Thanks.  I was getting stuck because a video was saying that I had to use a nested family to get the visibility parameter.  Didn;t think to load two titleblock families one with the label and one without.
Project Address Label
Thu, Feb 8, 2018 at 1:37:25 AM
Titile block label
Tue, Sep 16, 2008 at 11:15:27 AM
Revit 2009: Custom label in title view & Reference sheet
Mon, Dec 8, 2008 at 7:09:23 PM
Title sheet label
Wed, May 7, 2008 at 12:17:41 PM
Mult-line or Memo field in Title Block label
Wed, Aug 31, 2011 at 9:19:09 AM
Page generation time: 2.0221
