70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode
Wed, Feb 7, 2018 at 4:33:07 PM | Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode
bruff730
I have a file (one single file). No matter what i do in this file Revit will not Halftone or Fade out during and type of sketch or Edit mode. I have tried it in: Filled Regions, Masking Regions, Model inPlace, Any Sketch (Floor, Ceiling, Stair etc...), Design Options, Group Editer Mode (Detail and Model).
It works fine in any other project i can even windows tile and enter sketch mode in both project and it greys out background obejects in all files but one. I have tried to Purge, Audit, Re-Create the central model. Remove and Re-add worksets. Nothing fixes it.
Any thoughts? cant imagine why this is only happening in one single file.
Tue, Feb 27, 2018 at 11:18:54 AM | Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode
aandr001
4.5 Stars: 6 Votes
Hello Bruff730,
Not sure if I can answer your question, but perhaps a little clarification will help me out.
Are you referring to a "local" file that saves back to a central file?  The other local files that save back to the central file work fine, but not this particular local file?  If this is the case, perhaps just get rid of the "local" file that is causing the problem and create a new local.
One possibility (if I'm actually understanding your issue) is that you do not have permission to work on the local that you are trying to access.  This would be found in the work sets menu I believe.
Can't exit sketch mode
Tue, Oct 22, 2019 at 7:19:01 AM
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:57 PM
Stairs Disappear upon edit sketch mode.
Wed, Jun 6, 2018 at 12:49:19 PM
Floor creating mode greys out all tabs
Sat, May 10, 2014 at 5:50:41 AM
RST 2012 RIBBON IS ACTING CRAZY . . . while in sketch mode
Wed, Apr 11, 2012 at 3:36:07 PM
Page generation time: 2.1837
