27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Void Mass Not Cutting Divided Surface Mass
Tue, Jan 30, 2018 at 11:15:33 AM | Void Mass Not Cutting Divided Surface Mass
nikmunawwar
Hi there!
I'm kinda new with the conceptual massing environment, and am kinda stuck at cutting a divided surface with a void mass. I was able to cut the mass with the void, but when I divided the surface it seems to ignore the voids. Please refer to the attached image & (Revit file = https://drive.google.com/file/d/1E-vTVR3F_UtNvx_lPeRl0jgfGzk_NoBa/view?usp=sharing).
How do I go around doing it? It's quite frustrating.
Please help. Thanks!!!
Edited on: Tue, Jan 30, 2018 at 11:47:33 AM
Edited on: Wed, Jan 31, 2018 at 4:28:06 AM
Wed, Jan 31, 2018 at 10:19:22 AM | Void Mass Not Cutting Divided Surface Mass
nikmunawwar
OK I think I've got it.
You have to tab until you get to "Joined Solid Geometry: Face" <-- this is very important because as you cycle through the selections there will be another "Joined Solid Geometry" but that selection won't allow you to divide the surface (you'll notice the button won't be there).
Once "Joined Solid Geometry: Face" is selected, then you can divide it and it will divide only the geometries that are not cut by the void.
A bit tricky but worth the effort.
Hope this helps some people out there. Cheers!!
156658_2018-02-01_001244-Autodesk_Revit_2017_-_STUDENT_VERSION_-_3D_View_3D_-_Family1.jpg
How to cut mass conceptual divided surface
Mon, Apr 30, 2018 at 9:16:00 AM
Organic Roof Form [mass in place], voids not cutting
Mon, Oct 24, 2016 at 3:06:36 PM
wall by face not being cut by void in mass
Wed, Jul 17, 2013 at 3:33:07 PM
How to delete some in-place mass divided surface triangular curtain panel?
Sun, Jun 9, 2013 at 1:50:49 PM
In-Place Mass Family with divided surfaces can have seperate worksets?
Tue, Feb 2, 2016 at 7:18:27 PM
Page generation time: 0.5028
