88 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Center Reference Planes.......
Tue, Jan 30, 2018 at 8:42:45 AM | Center Reference Planes.......
JBRADLEY
Is there a way to have multiple "Center" Reference Planes in a Family, or assign more than one "Center" Reference Plane so that i can use Centerline Dimensions when placed into a project?  I am using Revit 2017
Tue, Jan 30, 2018 at 9:19:13 AM | Center Reference Planes.......
3.5 Stars: 395 Votes
You can have more than one reference planes in a family but each one must have it's own unique name.  You can name them whatever you want to otherwise and and setting that reference plane's options will allow you to dimension to it in the project.  Read THIS in your HELP.
Tue, Jan 30, 2018 at 9:32:45 AM | Center Reference Planes.......
JBRADLEY
I know this.....  But is there a way to assign, for example: 4 Reference Planes to Centerline witin a family so that I can use the centerline pattern on dimensions.   I am trying to dimension to centerline of Cabling holes on the top of a counter top.  Why can i change multiple Ref Planes to "Strong Reference", but not the same with (Center Left / Right)?  Am I missing something.
Tue, Jan 30, 2018 at 9:48:46 AM | Center Reference Planes.......
Center Left/Right is a system name and you can see all of those defined here.
For center's like you describe, I add a 2D line to the family in that location.
Constraining a circle centered between two reference planes
Fri, Apr 7, 2017 at 8:22:50 AM
View Reference center point is too far from the label.
Wed, Nov 19, 2014 at 9:24:13 AM
Listing the Abilities of Reference Planes
Sun, Sep 9, 2012 at 9:24:07 PM
reference planes
Wed, May 24, 2006 at 10:19:12 AM
Detail Lines and Reference Planes
Tue, Sep 20, 2016 at 2:37:46 PM
Page generation time: 0.4071
