69 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> DOOR SCHEDULE LEVEL NAME
0 Posts No Rating |
Is there a way to have the door schediule level show as a single digit rather than "1st Floor Plan"? I don't want to change the level name on the other sheets.
Nope. You're gunna have put up with it as it stands. Revit's data is interconnected to the 3D geoemetry. Its good as it means a single change, makes a universal change across the model but its bad in that its a little less flexible. It is what it is.
You can also add a parameter to doors that you fill in for this.
sort door schedule by level without adding "level" column? |
Tue, Aug 15, 2017 at 11:27:04 AM
Revit 2011 - Curtain Wall doors on Schedule for correct level |
Thu, Jun 7, 2012 at 1:22:49 AM
Schedule material mark in door schedule - Revit 2014 |
Fri, Jan 19, 2018 at 2:57:03 PM
Door Schedule |
Fri, Aug 17, 2012 at 7:07:50 AM
Linked door schedule sorted by level |
Fri, Jun 26, 2015 at 8:06:46 AM
Members: | 2017393 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
