65 Users Online (64 Members):
Forums >> Revit Structure >> Technical Support >> Shared Levels & Worksets
Working on a project using Revit, and the colaberation of Revit models using BIM 360 Team, i seem to always forget to put things on their rightful workset as i am modeling them. Is there a way to make it so that every time I place a new level, it atomatically goes to the Shared Levels & Grids Workset? or Everytime I place a beam or Coulumn it is assigned a workset I had created?
Thank you for your time!
-KraigZ
No way to have Revit think for you - too many rules to define that. This is a discipline that you have to learn and emphsize toother team members. The model/file is only as good as you make it and you need to be able to trust the model.
What I do is I review our file often lookinf for miss placed elements. For most 3D work, I use a 3d view with all worksets off then I turn on one at a time. I do the same with plans and where appropriate, elevation and sections. It doesn't take look when done regularly.
Groups & Worksets |
Sat, Dec 15, 2018 at 9:00:15 PM
WORKSETS |
Fri, Apr 17, 2009 at 10:37:22 AM
Worksets - Is there a way to? |
Tue, Nov 4, 2014 at 12:51:46 PM
Schedules & Levels |
Fri, Feb 24, 2006 at 2:08:54 PM
what is the fastest way to turn off annotations for linked revit files? |
Tue, Nov 17, 2009 at 3:22:16 PM
Members: | 2016897 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
