116 Users Online (115 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Embed plate visibility
Tue, Jan 23, 2018 at 5:54:02 PM | Embed plate visibility
chris505
I have created a steel plate family and placed it embedded into the surface of my precast concrete wall panel.
The plate is on the interior face of the panel, while the elevation view is of the exterior face. Is there a way to have these plates show on the elevation as hidden?
Thanks!
Wed, Jan 24, 2018 at 11:02:54 AM | Embed plate visibility
blue442
blue442 Avatar
Option 1: Good if only in 1 or 2 views, and only a few emeds
turn on wireframe mode on, use the Linework Overide tool and change them to a dashed line. Go back to hidden line mode.  You should see them dashed.
Option 2: Good if in multiple views and more than 1 or 2 embeds.
Edit the family, create a reference plane to represent the wall face.  Create a paramater to offset that work plane.  Draw model dashed lines in elevation on a the new reference plane.  Create a new category and place those lines on it so you have control on when you see them and do not.
Edited on: Wed, Jan 24, 2018 at 12:21:13 PM
How to Show a Recess of an Embed Plate
Wed, Mar 25, 2015 at 2:25:55 PM
Precast embed connections
Wed, Jul 30, 2008 at 11:22:13 AM
base plate visibility problem
Thu, Dec 1, 2011 at 12:34:33 PM
Column Base Plate Nested Family - GCS Visibility
Sat, Feb 21, 2009 at 9:17:59 AM
Sill plate?
Thu, Jan 28, 2010 at 5:10:16 PM
Page generation time: 0.3031
