54 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Level's elevation Base - Survey Point
Please help – Levels and the survey point
Please help!
My PBP and the survey point are at different altitudes.
When I change the level’s Elevation Base from the PBP to the survey point and vice versa, the elevation value remains the same.
What am I doing wrong? (use Revit 2017)
Thank you.
GHlen,
I know you watched those videos I posted a few years ago so I am assuming you are following that advice. So, how are your levels set? Look at their reference.
I'm pleased you remember me.
I watched this video again, -- it's a good one.
One level type is set from the PBP, the other one -- from "Reference". or Survey point.
The PBP is much above the Survey point. But both levels do not change the value of elevation, npthwithstanding i change their types (and, correcpondingly, their base level).
Both PBP and Survey points are clipped.
Thank uoy.
Topography Elevation from Project Base and Survey Point is Incorrect |
Thu, Jan 29, 2015 at 10:32:24 PM
Spot Elevation/ Level with both "project base point" and "survey point" 2017 |
Mon, Nov 27, 2017 at 5:33:42 PM
Level that reads both Project Base Point and Project Survey Point |
Tue, Jun 9, 2015 at 9:39:37 AM
Display both Project Base Point and Survey Point on Elevation Datum. |
Fri, Aug 29, 2014 at 5:57:41 PM
Project base point/ Survey Point |
Tue, Nov 13, 2012 at 3:35:36 PM
Members: | 2070178 | Objects: | 23097 | Forum Posts: | 152265 | Job Listings: | 3 |
