Forums >> Community >> The Studio >> Control Joints
Any tips on how to add some control joints like in the
picture attached? Would I have to do this with mass?
I wish it could work with wall reveals but it seems these
only work vertical and horizontal. Thanks
i am a bit new, only 1.5 years so maybe others will have a better answer.
have you considered a composite wall? for the initial look of it.
then, not sure, but could you create in place mini voids? or void sweeps?
or another idea - what about a simple wall based generic family, which creates a series of 'tiles', both full size and half size.
or how about just model lines? depends on your rendering requirements i guess.
i find, if in doubt, think how it would be built and try to emulate in revit. not always successful, but it helps!
Personally i'd just add a model pattern for the wall unless its something you really wish to model.
My method would probably be to create a wall hosted generic model family that cuts a series of swept voids out of the wall...
HTH.
Thanks, very helpfull tips.
Concrete control joints |
Thu, Mar 31, 2016 at 1:52:27 PM
11
Control Joints in a concrete slab |
Mon, Jan 18, 2010 at 2:21:39 PM
Line weight control |
Tue, Nov 21, 2017 at 2:14:39 AM
Line Based Family For Control Joints |
Tue, Sep 29, 2015 at 12:27:27 PM
Wall and floor joints |
Tue, Dec 30, 2008 at 10:42:08 AM
13
Members: | 2119028 | Objects: | 23205 | Forum Posts: | 152311 | Job Listings: | 3 |
