17 Users Online (16 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Trimming Wall Layers
Wed, Jan 3, 2018 at 8:47:20 AM | Trimming Wall Layers
mlarmand
I'm trying to create bump-outs on my facade.  In some areas these bump-outs will accommodate columns, but in other areas, the framing will just maintain consistency across the facade.  Therefore, the wall area I'm having trouble visually representing is where the bump-out framing is tying into the continuous wall framing (see below).  How can I trim out the lines representing the brick, insulation, plywood behind the bump-out framing (essentially creating a void between the framing)?  Thanks for your help
Wed, Jan 3, 2018 at 9:32:40 AM | Trimming Wall Layers
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I think the 'Cut Profile' tool under View > Graphics is your answer.
Thu, Jan 4, 2018 at 8:07:04 AM | Trimming Wall Layers
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
…or, use two walls for your main wall – structural wall and exterior finish (brick) and then just run the brick wall from bump-out to bump-out.
Thu, Jan 4, 2018 at 9:30:09 AM | Trimming Wall Layers
mlarmand
Thanks for the replies!  I can't believe it didn't occur to me to just make two wall types!  Thanks again!
wall layers not wrapping at curtain wall inserts!
Fri, Mar 4, 2016 at 10:27:08 PM
Scheduling Wall Layers
Wed, Nov 4, 2015 at 11:24:08 AM
Wall Layers in Section Views
Wed, May 5, 2010 at 3:46:43 PM
Wall Layers Modify
Fri, Dec 31, 2004 at 8:41:03 AM
Seperating layers hatch with filter
Wed, Feb 12, 2014 at 3:15:30 AM
Page generation time: 12.3836
