130 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Changing How Revit Displays North
Fri, Dec 29, 2017 at 11:42:41 AM | Changing How Revit Displays North
rebelarchitect
Hi all,
I am well under way with a project and need to change how Revit displays North. Rather than displaying North accurately (upwards) I'd like to have Revit display North to the left. Changing True North or Project North doesn't work in my case because I would like the building to be displayed as is, just with North in a different direction... is this possible?
Thanks!
Wed, Jan 3, 2018 at 7:50:18 AM | Changing How Revit Displays North
marmiketin1
4.5 Stars: 10 Votes
Just rotate your view on the sheet to however you want it to be.
Mon, Jan 8, 2018 at 10:28:45 AM | Changing How Revit Displays North
melnyk
Your description is a bit vague - I presume that you have True North & Project North both pointing upwards, and you want Project North to point upwards, but True North to point to the left.
You then say that rotating Ttue or Project North will not work in your case.
If you have rotated Project North to point to the left (that is set orientation to Project North and rotate 90 degrees to the left), when you set your orientation back to Project North, then you should be able to view Project North as upwards.
Let me know if this is not what is happening.
North Arrow
Fri, May 6, 2016 at 7:09:47 AM
Rotating views to project north
Mon, May 28, 2007 at 3:46:10 PM
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
True north is different that Revit north.
Sun, Mar 3, 2013 at 6:00:58 AM
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
Page generation time: 5.6967
