94 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Planting/ Trees not appearing correctly in Navisworks with NWC export
Fri, Dec 22, 2017 at 8:09:01 AM | Planting/ Trees not appearing correctly in Navisworks with NWC export
Sammo33
I'm having trouble when exporting a Revit 2017 model into Navisworks, basically the trees and other planting components all appear as grey shaded polygons with no material or detail. The trees and bushes have just been added as site components. Is it possible to export these into navisworks so that they view as they do in Revit ? I've attached an image file of the results i'm getting
Any help would be much appreciated, thanks!
Sun, Jan 7, 2018 at 1:48:06 PM | Planting/ Trees not appearing correctly in Navisworks with NWC export
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
If your planting is RPC's, they are made for Revit. Revit replaces them with photorealistic images. A low file size way of providing high resolution content. Navisworks probably wouldn't understand how they work.
Mon, Jan 15, 2018 at 11:30:40 AM | Planting/ Trees not appearing correctly in Navisworks with NWC export
Sammo33
Thanks for your reply Beaucoupnice
Regards Sammo33
Sat, Jan 20, 2018 at 3:44:33 AM | Planting/ Trees not appearing correctly in Navisworks with NWC export
archigrafix
5 Stars: 4 Votes
What expections do you have for the trees in Navisworks?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:15 PM
Navisworks 2016 Linked files not included when exporting to NWC file format
Wed, Apr 20, 2016 at 11:07:17 AM
Navisworks Question
Tue, Apr 28, 2015 at 1:17:16 PM
Revit to NavisWorks
Thu, Apr 17, 2008 at 9:26:44 AM
Revit 2018 - exporting from Revit to Navisworks, wrong format file not nwc !!!
Thu, Mar 15, 2018 at 3:25:55 PM
Page generation time: 0.4763
