97 Users Online (96 Members):
Forums >> Revit Building >> Technical Support >> 2D Reinforcing Family - not recognizing View Scale
Hi all,
Long story short, my new firm, is currently reinforcing slabs in Cad then Importing the Cad back to Revit..... ugh ....
I'm creating 2D reinforcing details.
Please see attached,
1- I have created Family Types for different Scales to control the Gap between the bars. However when I the load family into my project, I have to manually pick the scale. how can I have the family recognize the scale of the view it's being inserted to?
2- I will eventually try to create a Ribbon Button for the Reinforcing family otherwise I have to pick them from Annotate -> component -> detail component, so to add to the first question, will I be able to have the family recognize scale in the process of creating Ribbon Button? Any advice as to how I can attack the problem of Ribbon button creation.
Thanks
A detail is just that - a fixed detail view. If you are trying to import these into a plan, you don't want a detail.
i don't get the answer.
In my other firm, we had the same details and somehow the details could recognize the scale of the view, also we had a ribbon button for the details as well.
" If you are trying to import these into a plan, you don't want a detail " ... what do i need then?
visibility of reinforcing from linked structural model in architectural sections |
Thu, May 29, 2008 at 3:44:37 PM
Reinforcing Tags |
Thu, Jan 2, 2014 at 1:15:45 PM
REINFORCING MOVES MODEL |
Thu, Oct 6, 2005 at 3:36:36 PM
view scale parameter |
Thu, Jan 29, 2009 at 1:52:58 PM
Test Labels with psuedo dimension lines |
Fri, Oct 7, 2005 at 4:47:51 PM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
