75 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Window disappearing with changed sill height
Thu, Dec 14, 2017 at 6:43:29 PM | Window disappearing with changed sill height
Ryan043
Revit 2017
I am putting windows in a wall and at first they did not show up in the floor plan view. You would see the wall structure, but there would be no window until you moved your mouse over the spot where it was, then you could see the highlighted window. Today, I am able to put the same window into the wall and see the window in the wall now, but if I change the sill to above 3' 11" height, the window disappears. Below 4', the window shows up normally. I can see the window just fine in 3D view, but not in floor plan view. The wall just continues like there is not a window there.
I am also having a similar problem with a door. Where the door swing will not show up on one side of the wall and I have to have the door open the other way to show the door swing.
ALSO: I'm starting to see elements such as doors show up in alternate floor plan views. For example, I put a garage door on the 1st level and it shows up in the foundations as well. Same thing is happening with ordinary doors. They are set to 1st level, but they are showing up in foundations level as well.
I was really thinking I was getting Revit down and now this! This is madness! Help greatly apprciated.
Edited on: Thu, Dec 14, 2017 at 6:47:09 PM
Fri, Dec 15, 2017 at 7:57:22 AM | Window disappearing with changed sill height
marmiketin1
4.5 Stars: 10 Votes
Revit uses the view range cut plane that is associated in the family for how it shows in the project. Your issue is likely that your cut plane in the family is set to 3'11" and so in the project if your view range cut plane is above this number even if the window should be cut it will not show this way. What you need to do is set the view range cut plane in the family to something like 5' as pretty much all windows will start below this and and above this.
Fri, Dec 15, 2017 at 3:03:24 PM | Window disappearing with changed sill height
Ryan043
marmiketin1 Thank you, that was it! That is definitely important to know! Greatly appreciated.
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:49 AM
14
head height of window
Thu, Nov 3, 2005 at 5:19:14 PM
Actual Window Head height
Thu, Jun 7, 2007 at 5:44:29 PM
Sill and head height of windows - in the dimension I can only show the actual
Sun, Aug 18, 2024 at 1:01:15 AM
Default Constraints in window family
Fri, May 4, 2012 at 7:13:48 PM
11
Page generation time: 0.5194
