63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> curtain wall angled corner mullion
Mon, Nov 27, 2017 at 2:57:24 PM | curtain wall angled corner mullion
brankulo
hi, i am trying to achive the look per attached. this is tilt-up building so i am using curtain wall method but have trouble figuring out how to detail mitered connection at building corners. i tried to use rectangular profile mullion and rotate it 45 deg but the wall is not being adjusted to match diagonal. any workaround how to achieve this look?
thanks
Mon, Nov 27, 2017 at 3:40:40 PM | curtain wall angled corner mullion
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
It can be done but before I tell you how I suggest you not model this in 3D as its simply too much detail. Model it as wall at the correct thickness and wall buildup you need. Complete your plan and then create plan details and show this corner junction as a region fill and add in dimensions, text etc. Job Done. You are barely going to see the corner junction in elevations/3d, so I why bother.Nonetheless to do it anyway...Having done this type of precast concrete construction before, in that instance I used a curtain wall system. I created bespoke panels with angled edges to achieve that chamfered junction and bespoke corner mullions to achieve that jointing infil. That was 5 storey, $100M central energy plant with many different panel colours and jointing types though.As an alternative, you could create a normal wall with the correct finishes, thicknesses and buildup and stop just short of the corner. Then create an in-place wall and joint at the corner and join it to the system wall to remove the seam.
Mon, Nov 27, 2017 at 4:28:57 PM | curtain wall angled corner mullion
brankulo
 "I created bespoke panels with angled edges to achieve that chamfered junction and bespoke corner mullions to achieve that jointing infil"
so how do i do this? it will not allow me to modify profile in plan, only in elevation. i also was experimenting with angled mullions but i can not achieve this miter look.
Tue, Nov 28, 2017 at 12:28:35 AM | curtain wall angled corner mullion
Elnazer2
4 Stars: 5 Votes
hello,
first of all i join forces with beaucoupnice Beaucoupnice , i only did it as to extend my knowledge and to see if its even possible , so i  would suggest just detail it , but if you insist the way to do it is to do " Custom Profile Families " and keep manouvering between the offset of the mullion and the panel until you get the right shape ( don't mess with the angle ( that was my way ) ) , and actually i had to create 2 mullions Profiles "the right one" and "its mirror" ( i don't remember why to be honest ).
Hope this helps ,
Tue, Nov 28, 2017 at 8:49:21 PM | curtain wall angled corner mullion
brankulo
elnazer, i am sort of in a same boat, i like to learn and experiment with revit. thats why i want to know how to do this, in case i need to use corner mullion with this look sometime maybe. i keep playing with the mulllion profile but the problem i have is that the panel does not adjust to the mullion 45 deg angle. the panel always gets trimed at 90 deg angle. is there a trick to force it to get trimed diagonally to match mullion?
Horiz mullions wont clean up because of angled corner mullion
Wed, Oct 1, 2014 at 8:43:21 AM
Curtain wall corner mullion
Mon, May 15, 2017 at 8:33:53 AM
mullion join at angled mullion 2017
Sat, Oct 21, 2017 at 11:53:55 AM
Curtain Wall Angled Vertical Mullion
Tue, Feb 17, 2009 at 7:32:22 AM
corner join
Tue, Mar 14, 2006 at 3:52:39 AM
Page generation time: 0.7430
