120 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Structural Footing Lineweight Issue
Wed, Nov 22, 2017 at 11:12:10 AM | Structural Footing Lineweight Issue
jlabbe
Hi everyone,
I have a foundation/ground floor plan with structural footings underneath a concrete column. They show up as hidden, which is what we want. My problem is this. I cannot seem to manipulate the lineweights of the footings. We can change the linetype as well as the color but not the lineweight. We have tried the following: phasing, filters, graphics overrides, changing the <beyond> linetype etc... We are using Revit 2018. Any suggestions on why this would happen?
Wed, Nov 22, 2017 at 3:43:10 PM | Structural Footing Lineweight Issue
Look here.
Fri, Nov 24, 2017 at 1:11:08 AM | Structural Footing Lineweight Issue
Jezzza
I dont know if that works WWHub.. I thought that was only for annotation like lines/linework tool
I use Object Styles > Structural Foundations (expand) > Hidden lines change to be thicker
You will have to refer to your Line Weight table. It can be found here: Manage tab > Additional Settings > Line Weights (the numbers correspond to a weight)
Mon, Jun 18, 2018 at 11:47:50 AM | Structural Footing Lineweight Issue
teixeiranh
They might be using the "Beyond" style. Try and change that.
Mon, Jun 18, 2018 at 12:05:58 PM | Structural Footing Lineweight Issue
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If the footing isn't within the Primary View Range and there's no Plan Region it is using the Beyond linestyle.
Wall Footing Issue with Placement
Sun, Nov 21, 2010 at 9:22:08 AM
Offset structural bearing foundation footing?
Fri, Jun 19, 2015 at 10:19:41 AM
Structural Footing
Thu, May 11, 2006 at 11:47:55 PM
Visibility of foundation wall and spread footing in architectural views
Sat, Apr 19, 2008 at 8:24:01 PM
Stepped Footing
Sun, Nov 7, 2010 at 7:35:39 AM
Page generation time: 3.4842
