Forums >> Revit Building >> Technical Support >> Image applied in texture editor is inserted in the middle of surface
Tue, Nov 21, 2017 at 12:33:09 PM | Image applied in texture editor is inserted in the middle of surface
brookecanderson
I've created a sliding door panel, and when I attach an image for the panel finish it comes in centered on the door panel.  How do I change the insertion point of the image file???  I'm using Revit LT 2014.
Tue, Nov 21, 2017 at 2:32:19 PM | Image applied in texture editor is inserted in the middle of surface
Is this image one item that should cover the whole door?  If so then don't use a material, use a decal.
Tue, Nov 21, 2017 at 3:26:35 PM | Image applied in texture editor is inserted in the middle of surface
brookecanderson
The image is just supposed to cover the door panel, not the track or frame.  I've never used decals before, can you pick which surface you want them to be applied to?
Tue, Nov 21, 2017 at 4:21:00 PM | Image applied in texture editor is inserted in the middle of surface
A decal is face based.  If your panel is a seperate face, then the decal will only be placed there.
Tue, Nov 21, 2017 at 4:23:29 PM | Image applied in texture editor is inserted in the middle of surface
Be sure you understand decals... they only show in 3D views, not 2D elevations.
Tue, Nov 21, 2017 at 5:10:22 PM | Image applied in texture editor is inserted in the middle of surface
brookecanderson
A decal won't work then, I need the image to show up in a 2d elevation.  Any other ideas?
Tue, Nov 21, 2017 at 6:38:27 PM | Image applied in texture editor is inserted in the middle of surface
You need to associate a model hatch with your material.   Then you can use that in a 2D view to adjust where your pattern file is.
Look here and here and here.
Model surface pattern and material not aligned
Fri, Jul 6, 2018 at 8:58:24 AM
Inserted Image not visible
Fri, May 15, 2009 at 10:26:13 AM
Texture fix
Mon, Jul 9, 2012 at 1:25:13 AM
Can't Zoom into Inserted Image
Thu, Jul 1, 2010 at 5:06:11 AM
Locking inserted image/dwg file
Mon, Aug 29, 2011 at 9:38:25 AM
Page generation time: 2.0041
