47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> How do I create a Room Tag that has a text field that I can add comments too?
0 Posts No Rating |
I am working on a Revit model that has been linked into my project. I want to add a text field to the Room Tag so I can give each room a Type Number. Basically I want the Room Tag to say the name of the room, room number, and the designation I can manually add of "Type 1" or Type 2, 3, etc... Because I am linking in somone elses Revit Model, I can't edit this character as you would in a model you created from scratch.
Create a shared parameter in your shared parameter file, then add that parameter as a project parameter to rooms and edit your room tag also adding that parameter.
0 Posts No Rating |
Does not work. I created a shared paramter, added it to the label in the room tag. Loaded that same parameter into the project, the Room Tag label is still not editable.
You must have done something wrong. Did you follow all of the instructions? Have you worked with shared parameters before? The shared parameter must be created first and that file linked to both the project and the tag (in the family editor). This is NOT just a name.
Adding Optional Text Field to Keynote Tag |
Thu, Nov 13, 2008 at 8:52:47 AM
Schedules combining 2 text fields in to 1 |
Fri, Aug 10, 2007 at 12:27:28 PM
How can I add clear Height (floor to bottom of slab above) in a Room Tag? |
Sun, Aug 21, 2016 at 3:08:14 AM
How can I make a new tag (with new text field on the label) for Area plans? |
Thu, Jul 5, 2018 at 1:51:27 AM
View Tag - want to add a second line of text |
Sat, Feb 23, 2013 at 8:30:43 AM
Members: | 2022340 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
