122 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> creating General Notes (best practices/ efficient methods) 2017
Fri, Nov 17, 2017 at 11:05:40 AM | creating General Notes (best practices/ efficient methods) 2017
ledgewood33
i am looking to create General Notes for a project and possibly share those general notes between similar projects. i am looking for best practices and/or efficient methods others have used to create General Notes?
Fri, Nov 17, 2017 at 2:04:12 PM | creating General Notes (best practices/ efficient methods) 2017
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
For notes relating to the model i.e. notes intended to inform users of the model, I create a sheet and added them there, and then set the starting view to always open a model at that sheet. The sheet also contains the revision schedule for the model, the drawing schedule, a key/symbol section, a simple picture of the model and the model name.For notes that are to be issued on sheets, I first determine of the notes need to go onto multiple sheets. If so, I write the notes as a legend and drop them onto the sheet. If the notes as one-offs, then I place them as text on the sheet.
Fri, Nov 17, 2017 at 4:37:25 PM | creating General Notes (best practices/ efficient methods) 2017
I agree with Beau about using legends for notes to be used on multiple sheets but I don't like doing anything in a sheet view.  You can create a drafting view for one-of note blocks.   Drafting views are portable between projects using the transfer view.  You can use copy/paste for legend views.
Our standard notes are in legends in our template.
justification problems creating general notes.
Mon, Sep 21, 2015 at 9:24:19 AM
Importing General Notes
Wed, Feb 9, 2011 at 8:08:29 PM
Typing General Notes
Mon, Sep 20, 2010 at 1:32:39 PM
General notes & vent calcs
Tue, Oct 11, 2005 at 6:15:04 PM
Adding a General Notes section to our model spashscreen
Thu, Jun 13, 2013 at 10:03:02 AM
Page generation time: 3.4526
